Unknown Trap - searching the right MIB - Help please
tr0nic
Post by tr0nic » 11 Sep 2011 08:40
I´m trying to monitor an Alcatel OmniTouch Server via SNMP Traps on my Nagios. The problem is that SNMPTT can´t translate one SNMP Trap:
Sun Sep 11 12:54:03 2011: Unknown trap (.1.3.6.1.4.1.637.64.0.10.1.2) received from alcatelsrv
Value 0: alcatelsrc.local
Value 1: 10.50.1.2
Value 2: 0:12:23:14.73
Value 3: .1.3.6.1.4.1.637.64.0.10.1.2
Value 4: 10.50.1.2
Value 5:
Value 6:
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.637.64.0.10.1.1.1.1=89
Ent Value 1: .1.3.6.1.4.1.637.64.0.10.1.1.1.2=82
Ent Value 2: .1.3.6.1.4.1.637.64.0.10.1.1.2.2=5
Ent Value 3: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.1.1=89
Ent Value 4: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.1.2=alcatelsrv
Ent Value 5: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.2.1=29
Ent Value 6: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.2.2=1
Ent Value 7: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.3.1=23
Ent Value 8: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.3.2=2
Ent Value 9: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.4.1=175
Ent Value 10: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.4.2=0
Ent Value 11: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.5.1=82
Ent Value 12: .1.3.6.1.4.1.637.64.0.10.1.1.2.3.5.2=6
Ent Value 13: .1.3.6.1.4.1.637.64.0.10.1.1.3=2011/09/11 12:53:02
Ent Value 14: .1.3.6.1.4.1.637.64.0.10.1.1.4=4
Ent Value 15: .1.3.6.1.4.1.637.64.0.10.1.1.5=6
Ent Value 16: .1.3.6.1.4.1.637.64.0.10.1.1.6=15
Ent Value 17: .1.3.6.1.4.1.637.64.0.10.1.1.8=2053
Ent Value 18: .1.3.6.1.4.1.637.64.0.10.1.1.9=Terminal 6 in service
Please can you tell me which MIB i need to use that snmptt can translate this Trap?
Thanks a lot ;)
alex
Re: Unknown Trap - searching the right MIB - Help please
Post by alex » 13 Sep 2011 02:22
It is trap generated on an incident.
For SNMP MIBs check /etc/snmp/mibs/export directory on PCX.
Return to “SNMP Configuration”
