How to take console traces from oxo
shirantha
Post by shirantha »
Dear All
How to take console trase from oxo ?
Kindly help to me salve the problam...
Shirantha
shirantha77@gmail.com
Re: How to take console traces from oxo
Use serial port of the CPU. Connect using 115.200, 8N1, xon/xoff. user: swap_serial pass: alcatel. Reboot (warm reset). Check same port using same config for terminal.
Rikajo
Post by Rikajo »
You can read the status of the CPU V24 port, console traces or ppp for OMC ; use a browser and enter following URL : https://<cpu_ip_@>/services/webapp
Login is "installer" (no translation, in english only) and the installer password (same as for OMC session).
Return to “MAIN”
