configuring Disa
configuring Disa
if you please i want to configure disa on my oxo can any one help me with the steps or give me any documentation about disa and what features must be configured before configuring disa
Raaed Gerges
Voip Engineer
Mobile: +2 01144924461
Address: 9, Adel Roustom Street, Dokki , Giza, Egypt
E-Mail: R.Gerges@nubartrading.org
Voip Engineer
- cavagnaro
Re: configuring Disa
Just download and read the documentation available here. It is all explained there
Please note that DISA is a security risk and can be used to hack into your system.
If you read the 'Alcatel-Lucent Enterprise OXO security recommendations,' you'll see it being indicated as a feature which should be deactivated...
just saying...
good luck
just saying...
good luck
If I'm ever on life support, unplug me. Then plug me back in, see if that works...
