Hi, has a way to show the channel occupations on OXO with PCM-R2,
i need see total channels usage, and information when all channels are busy.
OXO PCM-R2 Usage
Re: OXO PCM-R2 Usage
You should create a resource key in add-on module to see channel by channel. It is the only way I know.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Hi, you need to do as Enio says above, but assign each channel as 'special physical address'
cheers
cheers
30 key !
stronge why a simple command is not avalaible as oxe .
have you seen in sysytem docf or last R
Hi Haroun
There is no command line in OXO as in OXE. At least for installer level. Everything is done in graphical OMC, where there is no monitoring for PCM-R2.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Thanks for reply.enio.eltz wrote:Hi
Best regards.
you can help me to create this resource key?
Thanks.
I need to know which command to use to monitor the performance of frame
Hi Guys,
You can also use 'metering' to check the occupation of your lines.
Just activate the metering over IP, install an Office Link Driver on your network and load the data to Excel.
You can filter on the moment and check how many simultaneous external calls were made...
Lots of fun
Creating the resource keys:
* Go to the details of your phone and select 'Keys'
* Click on the key and make it a Ressource Key - Special Phys. Access
* Select in the part below one of the lines
--> Make keys for every ISDN Trunk available.
Now you can monitor if an ISDN Trunk is used or not (you can't check if both channels are used though).
Good luck
Greets,
Koen
Lots of fun
Good luck
Greets,
Koen
If I'm ever on life support, unplug me. Then plug me back in, see if that works...
