Good afternoon, colleagues!
Got a processor that rebooted after the FAN lights up
When pouring software with a checkmark ticked VoiceOverIP through Lola, everything goes by hurray,
But after the software has filled up, the download reaches:
Image Name: PowerPC RAMdisk
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 5366944 Bytes = 5.1 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Booting using the fdt at 0x450000
Loading Ramdisk to 0fa80000, end 0ff9e4a0 ... OK
Setup_arch: bootmem
Ale837x_powercpu_setup_arch ()
Arch: exit
Safely sends all, and goes into reboot.
If to fill, without VOIP, then the station is loaded. Tried to add packets after installation,
Does not help, in the OMC does not allow you to select IP channels, although the license stands up correctly.
Release 9.2 failed to start if you include Voice Over IP in Lola
ACFE OXE Enterprise,ACFE OPENTOUCH,ACPS WLAN,AQPS OPENTOUCH
- Konstantinos.E
Re: Release 9.2 failed to start if you include Voice Over IP in Lola
the flash card under the power cpu... is working ?
Alca_holic
Here is some system start log from WebDiag
- > Creation of virtual boards :
Slot : 90 - Board : XRA - hb in slot : 1
status : accepted
Slot : 91 - Board : IVPS - hb in slot : 1
status : accepted
Comment : no restore, call handling is available
++ 0 ++ telephony is running ++ 0 ++
Slot : 98 - Board : MAIN_VOIP - hb in slot : 1
status : refused - cause : 12
Slot : 99 - Board : VIRT_MEDIA - hb in slot : 1
status : accepted
+ CPU TYPE : MAIN
ANV number : 3EH73084AKJE
db1 : absent
db2 : absent
db2 : absent
db3 : absent
db4 : absent
cCPU, theorical speed: 667 MHz
RAM size: 256 Mb
Flash size: 1961 Mb
mother voip 0 : DSPC6421
mother voip 1 : absent
Hard disk: absent
Slot 98 MAIN_VOIP refused
status : accepted
status : accepted
status : accepted
+ CPU TYPE : MAIN
db1 : absent
db2 : absent
db2 : absent
db3 : absent
db4 : absent
RAM size: 256 Mb
Flash size: 1961 Mb
Hard disk: absent
