PowerCPU EE R10 not boot up
doublevand981
Post by doublevand981 » 28 Jul 2017 22:12
Hi ALL,
I having OXO system running R10. But now it was failed to start .
i reloaded system by lola successful (R103_041_001). but switch back to normal mode the system still could not startup .
Pls help me to fix it !
below is V24 output:
U-Boot 1.3.0-rc3 (Nov 26 2015 - 16:16:13) 3EH30350ABAJ bootl100/001.009
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c4, MPC8377, Rev: 21 at 799.999 MHz, CSB: 399 MHz
I2C: ready
DRAM:
DDR DIMM: data bus width is 64 bit without ECC
DDRC ECC mode: OFF
DDR RAM: 512 MB
FLASH: 2 MB
PCI: Bus Dev VenId DevId Class Int
00 17 1064 2102 0000 00
In: serial
Out: serial
Err: serial
Net: TSEC0, TSEC1
eSDHC: High-capacity, 4bit-buswidth mode
SATA: SATA0 [Link: no RDY]
SATA1 [Link: no RDY]
PowerCPU in CPE Mode
## Booting image at ff837e6c ...
Image Name: aleboot.bin
Image Type: PowerPC U-Boot Standalone Program (uncompressed)
Data Size: 10092 Bytes = 9.9 kB
Load Address: 00200000
Entry Point: 00201d24
Verifying Checksum ... OK
OK
DIP switch: 0x0f
m41t11 Chip
No Prompt
Press ^B^I to enter into the Bios menu 0 Hit any key to stop autoboot: 0
## Booting image at ff83a618 ...
Image Name: gpioinit.bin
Data Size: 2850 Bytes = 2.8 kB
Entry Point: 00200750
OK
Watchdog Started
Waiting for PHY auto negotiation to complete...... TIMEOUT !
TSEC0: No link.
TSEC1: No link.
Using TSEC0 device
BOOTP broadcast request 1 in progress ---> 00:80:9f:be:62:41
Using TSEC0 device
BOOTP broadcast request 2 in progress ---> 00:80:9f:be:62:41
Using TSEC0 device
BOOTP broadcast request 3 in progress ---> 00:80:9f:be:62:41
Using TSEC0 device
BOOTP broadcast request 4 in progress ---> 00:80:9f:be:62:41
Using TSEC0 device
BOOTP broadcast request 5 in progress ---> 00:80:9f:be:62:41
Retry count exceeded; giving up
270 bytes read
Refreshing Watchdog... Watchdog Refreshed
## Executing script at 00100000
1967997 bytes read
6194511 bytes read
## Booting image at 00800000 ...
Image Name: Linux-2.6.29.6-rt23-026.003
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1967933 Bytes = 1.9 MB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
## Loading RAMDisk Image at 00e00000 ...
Image Name: PowerPC_RAMdisk
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 6194447 Bytes = 5.9 MB
Booting using the fdt at 0x450000
Loading Ramdisk to 0f9b5000, end 0ff9d50f ... OK
setup_arch: bootmem
ale837x_powercpu_setup_arch()
arch: exit
doublevand981
Re: PowerCPU EE R10 not boot up
Post by doublevand981 » 29 Jul 2017 07:17
here is my log file . The system Reboot infinite
HUSSAINQCS
Post by HUSSAINQCS » 29 Jul 2017 11:42
What is the led indication of the Power CPU ?
Is something done at the OXO side why system not coming up ?
doublevand981
Post by doublevand981 » 29 Jul 2017 21:41
The Fan led is off
The cpu led is green
Nothing happen at oxo side
ltatge
Post by ltatge » 30 Jul 2017 17:36
Just a thought, have you checked jumper on PowerCPU after LoLa? Is jumper in correct position?
Regards LT
doublevand981
Post by doublevand981 » 30 Jul 2017 21:06
I changed back to normal position after LOLA .
doublevand981
Post by doublevand981 » 30 Jul 2017 22:34
i would like to attach here the console trace on V24 port
ltatge
Post by ltatge » 31 Jul 2017 03:22
Try other PowerCPU, If same issue load software version new from Businessportal. If not, maybe a hardware issue with the board.
ltatge
Post by ltatge » 31 Jul 2017 03:26
OXO try to take into service DSP and fails.
See console trace:
=> PANIC RESET in cmvision.c line 6645 cause : CTRL DSP (80,00) : RES KO
May be a hardware fault.
doublevand981
Post by doublevand981 » 07 Aug 2017 02:53
Hi all,
i tried to reload software R103_039_001 and then system worked. i changed ip address and restore database then system worked well.
after some days turn off power and now turn it on they system failed again, boot infinite ( ip address back to default 192.168.92.246)
any pro can help me pls ?
Return to “MAIN”
