SEND CLIP TO 3dPARTY APPLICATION
telementor
Post by telementor »
hello
does anybody know how can i sent the cli of an incoming call to an external application(FOOD DELIVERY)?
over TAPI?over IP?
thank you
Re: SEND CLIP TO 3dPARTY APPLICATION
Depends...tapi could be but do they support such?
CTI is the answer, but would depend on your licenses and other party available integrations...what have they said?
telementor
thanks for your response
yes they support TAPI.they have made this with panasonic tapi 2.0,with nec sl-1000,and with asterisk.
if i install pimphony basic is it a good idea?because pimphony has TAPI 2.0.
Return to “MAIN”
