Block Incoming call
kapil_4596
Block Incoming call
Post by kapil_4596 »
We wants to block incoming call in oxo
Means, we wants that Mr. a can't call from his mobile ( 998899889988) to oxo PRI
Is it possible in oxo
KoenC
Re: Block Incoming call
Post by KoenC »
Hi Kapil_4596,
It's possible to block the call on a provider level, or use Smart Call Routing to reroute the number to a message or disconnect the call.
Smart Call Routing is a licensed feature on OXO, so I'd think you better contact your Alcatel partner/integrator.
If you already have the license, please check the installation manual or go to OMC > ACD (automatic call distribution) > smart call routing.
Good Luck.
Best Regards
If I'm ever on life support, unplug me. Then plug me back in, see if that works...
alex
Post by alex »
Well you can block calls from unwanted external number but on internal user basis, that means that you need to program "Selecive diversion" on every user.
Return to “MAIN”
