Database Restore failed: NMC Restore Failed
khutchins
Post by khutchins »
Hi all,
I am trying to restore the Database of my 4760 v.4.0.11.01 to the same version on a test server.
I am using the same computer name, DNS suffix is the same, I am using the same passwords when I reinstall the 4760. I have rebuilt the server and reinstalled 4760 multiple times. Still having the same issue
[2:50:55 PM] > Restore NMC: Compare files "C:\4760\RestoreContext.ini" and "C:\4760_ARC\4760Backup\20100326142556\RestoreContext.ini".
[2:50:55 PM] > Restore NMC: Retrieving "scheduler" service parameters.
[2:50:55 PM] > Restore NMC: Retrieving "loader" service parameters.
[2:50:55 PM] > Restore NMC: Retrieving "notify" service parameters.
[2:50:55 PM] > Restore NMC: Retrieving "alarms" service parameters.
[2:50:55 PM] > Restore NMC: Retrieving "LDAP" service parameters.
[2:50:55 PM] > Restore NMC: Retrieving "database" service parameters.
[2:50:55 PM] > Restore NMC: Pausing "NMC Service Manager".
[2:50:55 PM] > Restore NMC: Modify configuration of "NMC Service Manager" to stop some services.
[2:50:55 PM] > Restore NMC: - service "NMC Alarm server"
[2:50:55 PM] > Restore NMC: - service "NMC CMISE server"
[2:50:55 PM] > Restore NMC: - service "NMC Communication Server"
[2:50:55 PM] > Restore NMC: - service "NMC extractor"
[2:50:55 PM] > Restore NMC: - service "NMC GCS administration server"
[2:50:55 PM] > Restore NMC: - service "NMC GCS config server"
[2:50:55 PM] > Restore NMC: - service "NMC Loader"
[2:50:55 PM] > Restore NMC: - service "ORBacus Notify Service"
[2:50:55 PM] > Restore NMC: - service "NMC Pbx/Ldap synchronization"
[2:50:56 PM] > Restore NMC: Ask "NMC Service Manager" to apply changes now.
[2:51:12 PM] > Restore NMC: Stop of "NMC Scheduler".
[2:51:14 PM] > Restore NMC: Stop of "Sun ONE Directory Server 5.2 (4760)".
[2:51:22 PM] > Restore NMC: Stop of "NMC50 Database".
[2:51:24 PM] > Restore NMC: Restoring "NMC Save/Restore" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760".
[2:51:24 PM] > Restore NMC: Restoring "mib" files from "C:\4760_ARC\4760Backup\20100326142556\mib.ace" to "C:\".
[2:51:38 PM] > Restore NMC: Restoring "NMC Scheduler" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\data\Scheduler".
[2:51:48 PM] > Restore NMC: Restoring "NMC Loader" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\data\Loader".
[2:58:25 PM] > Restore NMC: Restoring "ORBacus Notify Service" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\data\Notify".
[2:58:26 PM] > Restore NMC: Restoring "NMC Alarm server" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\data\Alarms\Scripts".
[2:58:27 PM] > Restore NMC: Restoring "Sun ONE Directory Server 5.2 (4760)" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\Netscape\server5\slapd-4760".
[2:58:31 PM] > Restore NMC: Restoring "NMC50 Database" files from "C:\4760_ARC\4760Backup\20100326142556\" to "C:\4760\data".
[3:04:08 PM] > Restore NMC: Start of "NMC50 Database".
[3:04:13 PM] > Restore NMC: Start of "Sun ONE Directory Server 5.2 (4760)".
[3:04:21 PM] > Restore NMC: Modify configuration of "NMC Service Manager" to stop all services except "NMC Save/Restore".
[3:04:22 PM] > Restore NMC: Ask "NMC Service Manager" to apply changes now.
[3:04:29 PM] > Restore NMC: Update IOR for "NMC Save/Restore" in LDAP server.
[3:04:29 PM] > Restore NMC: Update IOR for "service manager" in LDAP server.
[3:04:29 PM] > Restore NMC: Wakeup or Reminder "NMC Service Manager"
[3:04:29 PM] > Restore NMC: To review configuration for "NMC Service Manager".
[3:04:29 PM] > Restore NMC: Failure
[3:04:29 PM] > Action Failed
Before I try the Database restore everything works correctly, after the restore fails 12 of the 15 NMC services stop and they are no longer in the service manager.
Any help or suggestions would be greatly appreciated.
Thanks!
corwin
Post by corwin »
My suggestin
you backup was down by the same running application
do you have still log of nmc save restore when performing this backup 2010 march 26 14H25
you may find in the log that backup has failed
you have same log in the 4760/data/scheduler : try to find the log by search a file generated around this date
file are splited per schedule job id
in the past i have asked for a restore option with a 4760 service stopped
i suggest you stop all sybase / sun one service / nmc servcie
and use to resotre another backup: 4760/bin/restore.exe
if all fails
supply the traces of nmc service manager.log
and check sun one service is running
khutchins
Post by khutchins »
I've checked the log for the back up and the back up was completed successuly sun one was running I will try to provide service manager.log
However I do not have 4760/bin/restore.exe- There is a save_restore.exe file but doesn't do what I need.
Any further help?
alex
Post by alex »
Actually the version 4.0.11.01 is not final.
Some bugs were corrected. Latest SW is 4.0.12.01.d. You'd better try latest version or even 4.1.
corwin
Post by corwin »
saverestore.exe is the binary file of service NMC save restore: you cannot launch it
R4.2.10.02d patch3 includes the latest patch for a successful defragmentation
one potential issue in restoring 4760 on other server is mistake on password
in svcmgr log you may find unable to connect to ldap server, while in fact it is running
all 3 password : dba, cn=directory manager and andminnmc are embedded inisde the database
since restore does only unzip of .ace file, whatever your initial password setup, after restore operation your 4760 use the paswwoard of the backup
except for NMC servcie manager
fnd parameter entry of svc_mgr in the registry (using regedit tool)
export the data from initial server : check no value depend on the old server (like path)
import in new server
khutchins
Post by khutchins »
I was able to pull the Log on the actual back up and I think that might be where the issue is
Here is the log. I hope this info might shed more lite on the problem?
[4/27/2010 12:28:45 PM] 3276 svc_mgr: disk limits not reached for NmcSaveRestore
[4/27/2010 12:47:36 PM] 4832 svc_mgr: going to sleep...
[4/27/2010 12:47:36 PM] 2164 svc_mgr: stopping AlarmServer services on all hosts...
[4/27/2010 12:47:37 PM] 2540 svc_mgr: stopping Cmisd services on all hosts...
[4/27/2010 12:47:37 PM] 4820 svc_mgr: stopping ComServer services on all hosts...
[4/27/2010 12:47:37 PM] 1764 svc_mgr: stopping Extractor services on all hosts...
[4/27/2010 12:47:37 PM] 3844 svc_mgr: stopping GCSAdmin services on all hosts...
[4/27/2010 12:47:37 PM] 3704 svc_mgr: stopping GCSConfig services on all hosts...
[4/27/2010 12:47:37 PM] 2020 svc_mgr: stopping Loader services on all hosts...
[4/27/2010 12:47:37 PM] 3328 svc_mgr: stopping NotifyService services on all hosts...
[4/27/2010 12:47:37 PM] 4156 svc_mgr: stopping SyncLdapPbx services on all hosts...
[4/27/2010 12:47:37 PM] 3508 svc_mgr: someone wants me to reload my configuration
[4/27/2010 12:47:37 PM] 3508 svc_mgr: closing LDAP connection
[4/27/2010 12:47:37 PM] 3508 svc_mgr: stopping service 'SyncLdapPbx@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:44 PM] 3508 svc_mgr: uninstalling service 'SyncLdapPbx@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:44 PM] 3508 svc_mgr: stopping service 'AlarmServer@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:46 PM] 3508 svc_mgr: uninstalling service 'AlarmServer@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:46 PM] 3508 svc_mgr: stopping service 'GCSConfig@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:47 PM] 3508 svc_mgr: uninstalling service 'GCSConfig@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:47 PM] 3508 svc_mgr: stopping service 'GCSAdmin@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:49 PM] 3508 svc_mgr: uninstalling service 'GCSAdmin@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:49 PM] 3508 svc_mgr: stopping service 'Cmisd@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:50 PM] 3508 svc_mgr: uninstalling service 'Cmisd@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:50 PM] 3508 svc_mgr: stopping service 'ComServer@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:51 PM] 3508 svc_mgr: uninstalling service 'ComServer@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:51 PM] 3508 svc_mgr: stopping service 'Extractor@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:57 PM] 3508 svc_mgr: uninstalling service 'Extractor@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:57 PM] 3508 svc_mgr: stopping service 'Loader@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:59 PM] 3508 svc_mgr: uninstalling service 'Loader@NBC-D1KDHNU6FUS'...
[4/27/2010 12:47:59 PM] 3508 svc_mgr: stopping service 'NotifyService@NBC-D1KDHNU6FUS'...
[4/27/2010 12:48:00 PM] 3508 svc_mgr: uninstalling service 'NotifyService@NBC-D1KDHNU6FUS'...
[4/27/2010 12:48:00 PM] 3276 svc_mgr: NMC service is paused : disk limits not checked.
[4/27/2010 12:48:15 PM] 3276 svc_mgr: NMC service is paused : disk limits not checked. <------- This error continues on for over 1 hour
[4/27/2010 2:00:06 PM] 3276 svc_mgr: NMC service is paused : disk limits not checked.
[4/27/2010 2:00:06 PM] 3520 svc_mgr: waking up...
[4/27/2010 2:00:06 PM] 720 svc_mgr: someone wants me to reload my configuration
[4/27/2010 2:00:06 PM] 720 svc_mgr: connected to LDAP server on NBC-D1KDHNU6FUS:389
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(AlarmServer) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(Cmisd) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(ComServer) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(Extractor) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(GCSAdmin) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(GCSConfig) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(Loader) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(NotifyService) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: Error: config_manager::_check_service() : open_service(SyncLdapPbx) failed.
[4/27/2010 2:00:12 PM] 720 svc_mgr: installing service 'NotifyService@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:12 PM] 720 svc_mgr: starting service 'NotifyService@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:14 PM] 4704 svc_mgr: Error: InternalAlarm DLL : Persistent problem while sending alarm.
[4/27/2010 2:00:14 PM] 720 svc_mgr: installing service 'ComServer@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:14 PM] 720 svc_mgr: starting service 'ComServer@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:17 PM] 720 svc_mgr: installing service 'Cmisd@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:17 PM] 720 svc_mgr: starting service 'Cmisd@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:18 PM] 720 svc_mgr: installing service 'AlarmServer@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:18 PM] 720 svc_mgr: starting service 'AlarmServer@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:23 PM] 720 svc_mgr: installing service 'Extractor@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:23 PM] 720 svc_mgr: starting service 'Extractor@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:25 PM] 720 svc_mgr: installing service 'GCSAdmin@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:25 PM] 720 svc_mgr: starting service 'GCSAdmin@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:27 PM] 720 svc_mgr: installing service 'GCSConfig@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:27 PM] 720 svc_mgr: starting service 'GCSConfig@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:28 PM] 720 svc_mgr: installing service 'Loader@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:29 PM] 720 svc_mgr: starting service 'Loader@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:31 PM] 720 svc_mgr: installing service 'SyncLdapPbx@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:31 PM] 720 svc_mgr: starting service 'SyncLdapPbx@NBC-D1KDHNU6FUS'...
[4/27/2010 2:00:37 PM] 720 svc_mgr: Warning: maximum disk limit reached for NmcSaveRestore
[4/27/2010 2:00:37 PM] 3816 svc_mgr: Error: InternalAlarm DLL : CORBA exception caught : System exception `OBJECT_NOT_EXIST'
Completed: no
Minor code: 0 while sending alarm.
Thanks for all the help thus far!!
corwin
Post by corwin »
this is a normal error during backup the disk control for overuse of disk capacity is in pause
this the main info of failure:
no moer backup will be performed since not enough disk on the drive that support 4760_arc folder
check now nmcsvc mgr.log it has similar issue i think for the drive that support 4760\bin or 4760\data
i suggest you remove/move unncecessary file including backup
Return to “OmniVista 4760”
