alcatel 4760 login problem
amar
Post by amar »
I HAVING LOGIN PROBLEM WITH OMNIVISTA 4760 CLIENT. THESE OCURRED WHEN I DELETED
"adminnmc" USER FROM DIRECTORY .IS THERE ANY WAY TO LOGIN ,I AM HAVING ACCESS TO LDAP DIRECTORY
KINDLY REPLY SOON
corwin
Post by corwin »
you can launch
4760\bin\dirmanag.exe tool
then from this tool connect as login: cn=directory manager
locate
o=direcotryroot > Administation > Administrator Goup
and add as member of this group an existing direcotry user entry (user need to have a password setup)
save your change with CTRL+S
amar
Post by amar »
login problem is not resolved as i cannot locate administration>administration group under o=directory root ,i am ready to send snap shot of dirmanag.exe tool
Is there any other way i can contact u (my contact no:9224342149)
alex
Post by alex »
amar wrote:...lots of shouting deleted...
:mad: first of all, do not shout or you'll be banned.
second, it is the most ignorant thing that I heard of - to delete "adminnmc" user of 4760. It is almost like "root" account in *nix systems.
Where did you come to that idea of deleting?!
If you do not know how 4760 works - do not touch anything in it or better read carefully the documentation.
corwin
Post by corwin »
I have only give you some guidance to solve by yourself the issue
the exact path is
directoryroot > yourDirecotryComanyName > administration > groups > administrators
if you have deleted adminnmc,
maybe you delete also other entries : like all directory entry starting by "a" including the default group
if it is the case; the only resolution of issue will be
uninstall 4760
reinstall 4760
restore the backup (performed before you lose the adminnmc account)
swinstu
Re: alcatel 4760 login problem
Post by swinstu »
Is there a way to recover adminnmc account in OV8770.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Return to “OmniVista 4760”
