Operator Action Command - without using MGR
eduardosaito
Post by eduardosaito » 13 Nov 2012 16:32
Sorry if I'm posting in the wrong section, just did it here cause we have a Genesys Call Center solution and Alcatel OXE ....
I need sometimes to manually change my test login status in mgr by using the "Cancel Withdrawal" option in the operators->action menu.
I'm trying to build a php script to do this change but I'm getting stuck when I'm going to type the Directory Number since my script has to put the cursor 6 lines below and I don´t know how to send a "down arrow" command.
Is it possible to do this by a single line command without using mgr?
Thanks in Advance.
Eduardo
Re: Operator Action Command - without using MGR
Post by tot3nkopf » 14 Nov 2012 03:54
Return to “GENESYS”
