Purge UCS database
lekie
Purge UCS database
Post by lekie » 12 Apr 2013 05:10
Have anyone know How to purge ucs database in version 7.6 and configure to keep data only 2 years?
Can I manage the data in ucs by genesys tools?
Thanks you in advance,
Lekie
Re: Purge UCS database
Post by cavagnaro » 12 Apr 2013 14:42
Using UCS Manager? You can move the UCS to UCS Archive using this tool and have both or just purge it
Return to “GENESYS”
