Hi All,
Is anyone know how to enable or disable screen pop pop on GAD client.
currently screen pop pop is disable, and want to enable it.
Deepak
Screen Pop pop on GAD client
- cavagnaro
Re: Screen Pop pop on GAD client
?? What do you mean by that? In GAD when a call arrives to your monitored extension it will show the details of that call
YES, Screen pop up for call details.
- cavagnaro
Again, there is no way to disable it naturally in GAD. Are you sure you are monitoring the extension? If you go to the Menu and select Place Status option, what do you get?
