Hi guys,
We have OXE 11.0 with CCS. WE have a main Piolt called "customerCare" where all the calls will land in. And we have another one pilot called "DataEsclation" . Always the "customer care" pilot agent will receive the call and transferred to "DataEsclation" Agent.
So when we genrate the report for "CustomerCare" Pilot , we are getting the Calls sum of the "DataEsclation" pilot also.
I can understand that, both are separate pilot and the transferred calls will be calculated as new call for the pilot.
But is there any way to customize, so that when i generate the report for "customercare" pilot it will show the details excluding the transferred calls details...
Thanks,
Rajan K.S
CCS Pilot report Modifications
Re: CCS Pilot report Modifications
Make a new template in the formpil file and exclude the transferred calls, make sure you take a copy of the template first, this is an excel job not very hard at all
- cavagnaro
I always was told never to remove, but to hide...
Cav, if you create a new sheet and then just link fields you can do what you want remove, hide, subtract all very easy!!
Hi OldBoy,
Thanks for the replay. i created a new Sheet from the temp file and then i copied the general tap fields and paste in the new Sheet.
But exactly i can't figure it out, how to exclude the transferred calls. Can you share the steps...
Rajan K.S
Rajan K.S
- cavagnaro
Like any excel file...exclude the column...
