Hi all,
I made an ACR configuration for a call center, with a pilot having two rules, first one with an waiting queue and the second with an acr activated waiting room, the EWT is calculated and working for the first one but noway with the second one , can any one confirm that the EWT works only with the regular waiting queue only.
Any help will be more than appreciated
Good day
EWT ACR
Re: EWT ACR
what do you want to do? explain it a bit more, please.
regards...
regards...
Re: EWT ACR
Hi there,
the config is as follows: I have a statistic pilot routed to a pilot and then to an ACR waiting room and then to an agent groupe , the issue is can't use Expected Waiting Guide in the waiting room as the system seems that its not calculating it ( EWT is always equal to 0 in the acr debug screen) and hence I can't use dissuation rule based in EWT calculation
Re: EWT ACR
so, how is the script that you use?
regards...
regards...
Re: EWT ACR
I'm off site ,so I will post it tomorrow
Re: EWT ACR
I dont believe EWT will work with ACR same a position in Queue doesnt work either with ACR enabled!!!
EWT ACR
hmm... i've never used it before, but there is a Expected Waiting Time Variable.
so it seams to work somehow... in logic it can be filled only after the system determined the possible agent list.
that's why i ask for more specific, how he was try to use it.
regards...
5.2.5.2.9 EXPECTED_WAITING_ TIME
The variable EXPECTED_WAITING_ TIME represents the anticipated waiting time for a call routed to a waiting room (in seconds).
Example:
IF (EXPECTED_WAITING_ TIME >= %120)
regards...
Re: EWT ACR
Hi All,
The issue has been solved , the first used script was based on the LIT rule only this way the system seems not to be able to calculate the EWT but after adding the ISM rule the estimated waiting time is calculated this way: at first when entering the waiting room and secondo after each reselection timeout
the script used is:
START
IF (EXPECTED_WAITING_TIME < %600) /* put the same value as WRoom Max waiting time */
APPLY
RULE_ISM CHARACTERISTICS_LIST,
RULE_IDLE_TIME
RESELECTION_TIMEOUT = %10
ELSE
APPLY
RULE_REDISTRIBUTION
ENDIF
END
Thanks for all the posting
the script used is:
START
APPLY
RULE_IDLE_TIME
ELSE
APPLY
RULE_REDISTRIBUTION
ENDIF
END
Re: EWT ACR
nice, thanks for sharing the solution!
regards...
regards...
