AgentWidget Color
FN_DK
AgentWidget Color
Post by FN_DK » 10 Dec 2012 03:18
Hi All,
I have been searching this forum for a way to change the status colors of the AgentWidget. Haven't really found the answer yet.
So, does anyone have had any success with change the status color of the AgentWidget? (Not the bagground color)
Softpanel 5.9.0.0
OXE R9.1
ecoenraad
Re: AgentWidget Color
Post by ecoenraad » 13 Dec 2012 06:10
To change the color status of the agents you have to edit the follow file:
‘C:\SoftPanelServer\tomcat\webapps\wbm\js\view\agentwidgetpremiumdisplay.js’
There's a section starting with 'function AgentWidgetDisplay() {'. The colors defined in this section represent the agent state colors.
After changing you need to restart the SoftPanel service.
I hope this helps.
FN_DK
Post by FN_DK » 18 Dec 2012 04:01
Forgot to say it was on a CCD standard call center. So I just picked the file associated to CCD standard.
It worked like a charm! Thankyou for helping with this.
Best Regards
Return to “Call Center SoftPanel (ALU ProServices)”
