upload wav file to SoftPanel
yoavb
Post by yoavb »
Hi All,
Could someone tell me what should be the wav file format to upload new files to the Soft Panel alarm option? I tried many formats but nothing actually were uploaded and been played.
Thanks in advance
yoavb
Re: upload wav file to SoftPanel
Post by yoavb »
Any answer on that?
I have no clue but what I'd do is to grab an existing one and just see its format and properties. Then copy them and apply to new files.
yoavb
Post by yoavb »
I tried to but I don't find the way to download the file. There is only "upload" new file.
I also searched for the "Audio" files on the server but without luck. Even on the SoftPanel doc's, there are nothing on that.
Return to “Call Center SoftPanel (ALU ProServices)”
