How to use "incoming","initiated" attribute in my ip touch xml applications
pavsuri
Post by pavsuri »
Iam trying to create an application to make it visible into one of the telephonic menu for the caller.
Basically I want to declare an application in such a way that at startup time a softkey can be specified for the applicaiton for each telephonic states as below:
• Call incoming
• Call initiated
• Call delivered
• Call established
• Call conference
• Call on hold
• Call disconnected
I went through the developers guide and was able to display the application name in the MENU Tab but no help was there to display in one of the telephonic menus.
According to the Developers Document , it is given that “There is no help available for applicative softkeys”. Due to Lack of More information about this part iam unable to display the application name in the Telephonic Menus.
Please see my below snippet of Code for Registration and Config File. Please specify where am I going wrong.
Registration.php file
<?php
header('Content-Type: text/XML; charset=UTF-8');
echo '<?xml version="1.0" encoding="UTF-8"?>';
echo '
<body xmlns="http://www.alcatel.fr/IPT/v1.0">
<register>
<url id="config" value="http://192.168.1.112/suris/Sun/Test/Config.php" />
<prop id="rights" value="no" />
<prop id="key" value="14" />
<timer id="NotifyScanPeriod" value="800"/>
<http>GET</http>
</register>
</body>
Below is my Config file:
<?php
header("Content-Type: text/XML; charset=UTF-8");
<connect>
<device>
<model>IPT 4068</model>
<model>IPT 4038</model>
</device>
<app_name>
<lang id="en-GB" value ="Ho" incoming ="answer"/>
</app_name>
<app_help>
<lang id="en-GB" value="Hotel info"/>
</app_help>
<url id="main" value= "<?php print ("http://192.168.1.112/suris/Sun/Test/main.php"); ?>"/>
<url id="notify" value= "<?php print ("http://192.168.1.112/suris/Sun/Test/Notify.php"); ?>"/>
<url id="error" value= "<?php print ("http://192.168.1.112/suris/Sun/Test/Error.php"); ?>"/>
<url id=”callstate” value=” <?php print ("http://192.168.1.112/suris/Sun/Test/callstate.php"); ?>”/>
<rank_info>4</rank_info>
<aa_dig_sgn>208375444ae944199e9fc51cbec127768a58d8 9efc042283f65146132b26e5d8631dbde96824d5d9a622179e e33be0623ca4bbd3480720614f6a9391b52fe6cf</aa_dig_sgn>
</connect>
</body>
Help on this is really appreciable.
charliebrown408
Post by charliebrown408 »
These are the basics of the tracing the incoming call through xml:
Call incoming
• Call initiated
• Call delivered
• Call established
• Call conference
• Call on hold
• Call disconnected
But for deploying the xml, you have some scripts from where we can store our trace data.
like:
<info>
<name>xym</name>
<number>1234567890</number>
</info>
like that.
pavsuri
Post by pavsuri »
Dear charlie,
I thank you so much for giving a response for my post.
I was clear with the call states but i want to know from the presentation server how will the application residing in the web server come to know that it is an incoming call for the caller and also on the incoming call i want to place an soft key in the telephonic menu that is in the caller menu he gets when he receives the call.
Please go through my config file sent in mhy previous posts and suggest me where am i going wrong.
i referred the documents provided by alcatel.
regards,
20deoctubre
Re: How to use "incoming","initiated" attribute in my ip tou
Post by 20deoctubre »
What do I need to build this kind of applications, I know XML but I don't know how to use it with Alcatel services. Where can I find information about this ? Does it work with OXO?
Return to “IpTouch Phones XML Applications”
