How to get Presentation Server?
brianj
Post by brianj » 18 Jan 2013 19:42
I would like to develop some demonstration applications for the IP Touch phones. What is the easiest way to just get the presentation server? Do I need Open Touch for that? I've looked through all of the software available for download and do not see anything that just says "Presentation Server".
Thanks!
Brian
Re: How to get Presentation Server?
Post by cavagnaro » 19 Jan 2013 08:24
Well PRS is part of ICS (OTUC) actually...ICS is embedded on OpenTouch.
There was the XML Presentation Server that could be installed standalone...it was under ICS category. But still would require licenses on OXE and ICS/PRS side so you need to talk with ALU.
If you are a partner you can buy a lab kit.
brianj
Post by brianj » 19 Jan 2013 12:15
Thanks for the quick reply! I have been looking around on the BPWS and I can't seem to find the standalone version of the PRS. Do you know if it is stall available? I have the licenses for the OXE side - do I also need licenses on the PRS itself?
Brian
Post by cavagnaro » 20 Jan 2013 08:38
Well probably they now removed it...licensing changed. Yes, you need licenses on ICS side too. Weird you have licenses on OXE side but on a PRS license?? How??
Talk to your presales guy and ask him to purchase an ICS but only with PRS licenses and that is it.
brianj
Post by brianj » 20 Jan 2013 11:56
So, since this is a test environment, I managed to force the loading on to CentOS and I got the server up and running. I do have licenses on the PRS side and on the OXE side (they are from an Open Touch server?). The only thing I can't find are the example applications - I have the examples for all of the web services except the Weather, LanCam and SMS.
Thanks again!
Brian
Return to “IpTouch Phones XML Applications”
