Hi everybody,
I have a problem : i could not import voice guide to 4645 AA by using Eva tool
The Oxe MG' version is: R9.1-i1.605-21-tr-c82
The PBX is working in USA so I installed USA database.
system's law is Mu law.I imported the voice by using
ftp under usr7/var/tmp nad wanted to use Eva_tool:
but unfortunatelyI always have this error:
Your choice :12
Sorry system is not initialized: check language or the system law
MANAGEMENT TOOL
0 : End
1 : Delete a mailbox
2 : Modify a password
3 : Delete all messages from mailbox
4 : Delete messages
5 : Dump nodes, mailboxes and messages
6 : Reset a port
7 : Update led
8 : Status of lines
9 : Disable lines after hanging up
10 : Force disable all lines
11 : Enable all lines
12 : Interactif import of greeting
13 : Automatic import of greetings
14 : Mov_debug
Your choice :
Any Ideas? What can I do? thanks for your reply
4645 Voice mail AA Importing Voice Guide for USA Problem
Re: 4645 Voice mail AA Importing Voice Guide for USA Proble
you can stop telephone
run Eva_tool
formatall command
start telephone
auditmevo command
run Eva_tool
formatall command
start telephone
auditmevo command
thanks for your reply royman
I tried and worked.thx
Re: 4645 Voice mail AA Importing Voice Guide for USA Problem
What does formatall command do?
I need to set this up on mailbox for afterhours message for which a customer has provided a wav file converted through AAS.
how does this affect all setup mainlboxes, I am wondering.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
ACSE OXE R12.1
SWINSTU
ACSE OXE R12.1
ACSE OXE R12.1
