Hi all,
I am facing new issue on 4635 & release R8.0.g1.302.6.e..,
Scenario : A is an internal user and B is an internal user,
If A calls B , When B is not answering after 4 rings it will be forwarded to Voicemail and User A can leave a Voice MSG ..,
Later User B can retrieve the Voice MSG left by user A .........., the problem is the user B has a digital 4029 digital set and the date & time will be displayed of that msg will 2085/07/11...........,
I COULD NOT KNOW WHERE IS THE ISSUE..,
I LOG IN TO 4635 ALSO & VERIFIED DATE & TIME AND IS CORRECT............,
voicemail Date & Time Incorrect
Rajkumaaaaaaaaaaaaaaar
Rajkumaaaaaaaaaaaaaaaaaar
Rajkumaaaaaaaaaaaaaaaaaaaaar
Re: voicemail Date & Time Incorrect
what is your 4635 version? is that working with vpu6 ?
A4635h/vpm35 Software Release 5.4.2
attention to TC2051 the A4635 system may be become unuseable or have some bug after November 24, 2015 and you need to upgrade your 4635 to release 5.6.5
Is there any solution without upgrade
Nope.....
