Voice mail 4645 was silence after bascul
HUSSAINQCS
Post by HUSSAINQCS » 03 Oct 2017 07:49
Dear All,
After double bascul the voice guides of voice mail stopped working also in incidents i can see
The download of the /DHS3ext/vgeva/evavg.EN0 language file failed
But the voicemail showing in service when execute the command
config 18
Also vmail showing free all ports
Actually i have done binary upgrade of phones from 4.52.60 to 4.52.80 may be this could be the issue ?
HUSSAINQCS
Re: Voice mail 4645 was silence after bascul
Post by HUSSAINQCS » 03 Oct 2017 07:54
i have resetted the virtual shelf 18 but in incidents it was showing
VOCAL facility starting link but no voice guides for voicemail
in DHS3ext/vgeva/evavg.EN0 file is there in that directory
How can i resolve ?
Post by cavagnaro » 03 Oct 2017 10:34
You have to upload the guides to both CPU not just main
oldboy
Post by oldboy » 03 Oct 2017 18:41
What is the language set to in the 4645 config?
HUSSAINQCS
Post by HUSSAINQCS » 04 Oct 2017 05:49
EN0
Post by vad » 04 Oct 2017 08:42
In config - you can manage "English", not EN0.
What about question - "You have to upload the guides to both CPU not just main?" from Cav.
HUSSAINQCS
Post by HUSSAINQCS » 04 Oct 2017 08:46
but the main CPU was up why the voice guide of voicemail alone not playing ?
Post by cavagnaro » 05 Oct 2017 10:00
Up doesn't mean active...so the active partition doesn't link to the main cpu where guides are, but to your backup. In that moment your Main was CPU b. Not A.
Return to “Voicemail (46x5)”
