Event CSTA server every hour
PabloR
Post by PabloR »
This days I am watching the events 4019, 4018 and 4019 relating to the connection between the CS - OTUC every hour. All services run fine, but these events worry me.
27/01/12 00:20:49 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 00:20:49 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 00:20:52 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 01:21:55 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 01:21:55 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 01:21:59 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 02:22:54 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 02:22:54 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 02:22:57 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 03:24:12 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 03:24:12 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 03:24:15 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 04:25:06 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 04:25:06 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 04:25:09 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 05:26:25 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 05:26:25 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 05:26:28 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 06:27:46 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 06:27:46 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 06:27:50 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 07:29:22 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 07:29:22 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 07:29:25 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 08:30:51 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 08:30:51 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 08:30:54 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 09:32:32 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 09:32:32 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 09:32:35 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
27/01/12 10:34:31 000001M|---/--/-/---|=3:4019=CSTA server : 1 exit
27/01/12 10:34:31 000001M|---/--/-/---|=4:4018=CSTA server : 1 connection closed
27/01/12 10:34:34 000001M|---/--/-/---|=4:4017=CSTA server : new creation 1 10.70.0.8
The OTUC and CS are connected to the same switch with the same IP range.
CPU address : 10.70.0.10
Twin CPU address : 10.70.0.12
OTUC: 10.70.0.8
Teamwork: 10.70.0.9
sipregister
Dump local registrar base
Address of record : 29997
contact : sip:29997@10.70.0.8:5070, UDP, 3466 s
Address of record : 29990
contact : sip:29990@10.70.0.9, udp, 915 s
Address of record : 29998
contact : sip:29998@10.70.0.8:5070, UDP, 3466 s
Address of record : 29994
contact : sip:29994@10.70.0.8:5070, UDP, 3466 s
Address of record : 29991
contact : sip:29991@10.70.0.8:5070, UDP, 3466 s
Address of record : 29999
contact : sip:29999@10.70.0.8:5070, UDP, 3466 s
Address of record : 29995
contact : sip:29995@10.70.0.8:5070, UDP, 3466 s
Address of record : 29996
contact : sip:29996@10.70.0.8:5070, UDP, 3466 s
****** registred user number : 8
Any idea what may be the problem?
thx!
krzysioD
Re: Event CSTA server every hour
Post by krzysioD »
Otuc version, with every little sub-patch, PBX version with every little sub/dynamic patch.
Looks like more somekind of hot-fix to restart someting every hour than a bug...
PabloR
Post by PabloR »
I will talk with OTUC integrator.
thx krzysioD
Return to “OTUC”
