Teamwork x OXE call does not work
joao.carlos
Post by joao.carlos » 24 Jul 2013 11:15
HI,
I have two problems:
1. Following the documentation, we have to create a External Voice Mail and register it on Teamwork as the outgoing user.
When i do this, OXE does not allow external calls, only calls to users inside OXE. So, if in the conference i need to call a public number, for example, it does not work. I receive NOT ACCEPTABLE HERE.In this same configuration, when i use an SIP EXTENSION as the user mentioned above, it does make the external calls, so i think that is no CODEC problem. The number (DAS RULES) is arriving on OXE perfectly, with the ARS prefix + external number.
2. When using this SIP EXTENSION as the outgoing user, the external call works, but it does not "close" the conference.
If I'm connected (logged) on teamwork and set my number as a local extension, when i call a external number, the following occurs:
a. Teamwork calls my extension; OK
b. I answer the call; OK
c. Teamworks dials the external number (and I'm listening to OXE MOH); OK
d. When external number answers the phone, both sides (me as internal user and the person in the external number) keep listening to OXE MOH;
e. After some seconds, call is released on both sides;
If I'm logged on and set my actual number as an external one, and try to call an Internal OR External number, following occurs:
a. Teamwork calls my actual number (external); OK
c. Teamworks dials the other number (internal or external);
Here I receive (INTERNAL NUMBER):
2013-07-24 12:10:30.070126
SIP/2.0 488 Not Acceptable Here
Via: SIP/2.0/UDP 10.176.9.4:5060;branch=z9hG4bK77758287;received=10.176.9.2:5060
Call-ID: 696434863@10.176.9.4
CSeq: 1 INVITE
From: "teste" <sip:7999999@10.176.9.2>;tag=6774375477758285
To: <sip:7041770@10.176.9.2:5060>;tag=ea223265aaf1faf9d5ea36aa4c681f85
User-Agent: OmniPCX Enterprise R10.1.1 j2.603.13.f
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Reason: SIP;cause=488;text="Outgoing call isn't allowed here"
Content-Length: 0
OR (external number):
2013-07-24 12:51:50.369196
Via: SIP/2.0/UDP 10.176.9.4:5060;branch=z9hG4bK77758347;received=10.176.9.2:5060
Call-ID: 696434869@10.176.9.4
CSeq: 1 INVITE
From: "teste" <sip:7999999@10.176.9.2>;tag=6774375477758345
To: <sip:092230000@10.176.9.2:5060>;tag=0d12518a95c29be3e366183a66a93ebd
Content-Length: 0
d. And in the first call (my actual number), i hear the busy tone, than the TTS telling me that i'm the only one in the conference, and keeps playing, this time, TEAMWORK MOH. The other party never receives a ring.
Anyone can help?
joao.carlos
ACSE OXE R12 | ACSE OpenTouch R2 | ACSE OXO Connect R2 | ACSE OmniVista 8770 R3 | ACFE OmniSwitch R6/R7/R8 | ACSE OTCS R8.2
ACPS IP Telephony R12 | ACPS OpenTouch R2 | ACPS Data Networks R6/R7 | ACPS OTCS R8.2
Re: Teamwork x OXE call does not work
Post by cavagnaro » 24 Jul 2013 13:03
check the public category of the trunk group
joao.carlos
Post by joao.carlos » 24 Jul 2013 13:07
SIP (Teamwork): 31
Outgoing (R2 or SIP if mobile): 0 or 31
They have Connection between them.
joao.carlos
Post by cavagnaro » 24 Jul 2013 14:23
And does 31 has priviledges to dial out?
joao.carlos
Post by joao.carlos » 24 Jul 2013 14:26
Yes. I put the right to ARS too.
I managed the user permissions and was able to call now, the two stations (internal/external), using External Voice Mail account, but now i have no voice, call stays mute.
SIP shows me no error.
joao.carlos
Post by cavagnaro » 24 Jul 2013 18:14
No voice means RTP problems. Check your firewall.
Sent from my XPeria Z
joao.carlos
Post by joao.carlos » 24 Jul 2013 20:01
Well, i'll double check, but it's strange.
I'm on an analog phone (as internal number) and external number is called by a TG in the same media gateway. It means that both sets are managed by the same GD board, isn't it?
joao.carlos
Post by cavagnaro » 24 Jul 2013 21:34
Try to maintain the conversation more more than a minute, does it keeps on or is released?
If released check codecs
Return to “OTUC”
