IMAP and BLACKBERRIES
Post by frank » 04 Feb 2010 02:00
I heard about this company that has a software that gets the voicemail using IMAP directly into your INBOX. Therefore, you can get your voicemail in your crackberry emails !
Check out:
http://www.jam-software.com/smartpop2exchange/
Sulman A
Re: IMAP and BLACKBERRIES
Post by Sulman A » 13 Jun 2011 02:18
Well you can send your voice mails on black berry or any mobile device integrated with exchange. You can use ICS UM method for this purpose, All you have to do is to create one mail server & transfer server & a voice no with type UM.Its an imap mail can only be played as sound clip. I tried that N its working fine for me. no need of any additional s/w.
Return to “My Messaging / IMAP”
