Voicemail answer only
omarsoto
Post by omarsoto » 24 Apr 2013 06:11
Hi, i'm trying to configure a voicemail answer only in an IC8400 Suite but the system always tell me options after my message, it's posible to configure a real answer only voicemail?
Regards.
Re: Voicemail answer only
Post by cavagnaro » 24 Apr 2013 23:13
Create a template and also modify user personal configuration
Return to “My Messaging / IMAP”
