AHL Simulator - Wrong content sent in frame
L_lefante
Post by L_lefante »
Hi all,
I am trying to use AHL simulator.
When I try to send frames to test there is some content added and i don't know where that is comming from.
For example,
I am trying to do send a check out frame for room 6710... However when I edit the content that i want to send it change it to 671044. Please see the attached files.
This is what i see in OXE trace:
1443725731 -> === TRAME RECEIVED length=12 D~~~~671044 - PB - envoi du nack vers PC
Is this a problem of the simulator??... Did anyone face a similar problem??
sadim2
Re: AHL Simulator - Wrong content sent in frame
Post by sadim2 »
There is nothing wrong with the AHL simulador, 44 is the checksum of the message.
The depart is being refused by some other reason (room not in checkin state, busy line, ...).
Best Regards
L_lefante
Post by L_lefante »
So what you are saying is that this is a normal behaviour???
Checksum is always sent like this in rhe frame??
Thanks for your help.
sadim2
Post by sadim2 »
Yes, that is normal.
If you change the room number, then you will see that crc will also change.
L_lefante
Post by L_lefante »
OK.
Thanks for the clarification.
Regards.
Return to “Hotel / Hospital”
