Multi-occupancy
cjavelle
Multi-occupancy
Post by cjavelle »
I want to use Guest Management for my Hotel application but when i active "Guest Management" on mgr / Application / Hotel / Management Mode
I receive this message :
Management mode: Forbidden : inconsistency multi-used function - station
And When I create a User with Use Type Of Dir. No. to Multi Occupation, i have this message (Hotel-Set Function si to Room and set type is analog) :
OBJECT -1: ATTRIBUTE 0: Forbidden : inconsistency multi-used function - station
I'm trying different mode for Multioccupation Type in mgr / Application / Hotel / Numerical Parameters / Multioccupation Type but the result is the same.
Coul'd you help me?
oldboy
Re: Multi-occupancy
Post by oldboy »
Do you have any rooms already programmed in the system? As you cannot change mid way through whole system needs to be Mulit Occ
cjavelle
Re: Multi-occupancy
Post by cjavelle »
Yes it was the problem.
I'm deleting room and after I can modify Management modeet create new room with multi-occupation
Return to “Hotel / Hospital”
