Is it used posiible CSTA for OXE SDK ?
thkim81
Post by thkim81 » 23 Oct 2011 22:06
Hi~
I searching for CSTA for oxe SDK.
manual is indicated it used ok.
Where am i dowonload the SDK ?
pls answer the question.
thanks
PS : I attaching the manual Page 10.
CSTA for OXE is ok check
krzysioD
Re: Is it used posiible CSTA for OXE SDK ?
Post by krzysioD » 27 Oct 2011 17:21
Simply,
you need to regiser to a AAPP, attend some trainigns, pay some Euros, buy some demo site and then you could download all that you want.
thkim81
Post by thkim81 » 27 Oct 2011 20:30
I register to AAPP. and eSR open the question. but not yet. and AAPP can not SDK for OXE only SDK for OXO
just know. Is really existence ? I can buy that. If existence , I'll buy it.
thanks
krzysioD
Post by krzysioD » 28 Oct 2011 03:11
It does. Some guys here (like me :-D ) simply use it.
on your AAPP you have OXE contract or only oxo?
thkim81
Post by thkim81 » 28 Oct 2011 05:34
contract ? What contract ?
actually, I'm not used that. co-worker recording developer will use.
I just search it is being SDK.
Return to “TSAPI”
