FAX Demo License
pgemelgo
FAX Demo License
Post by pgemelgo » 28 Feb 2011 03:14
Hi All
We have just installed an ECS 4.2 with Fax server with licenses, but still we get the DEMO showing on the Fax server, anyway to get this problem solved?
Pedro
Re: FAX Demo License
Post by tot3nkopf » 28 Feb 2011 05:18
Did you bought FAX server licenses?
pgemelgo
Post by pgemelgo » 28 Feb 2011 07:43
Yes, we did, but I suspect that we havent been sent the licenses, so following up on that now, as the ECS is working with no license issues.
Post by tot3nkopf » 28 Feb 2011 13:17
pgemelgo wrote:Yes, we did, but I suspect that we havent been sent the licenses, so following up on that now, as the ECS is working with no license issues.
I do suspect the same thing.
Return to “AECS - Alcatel Extended Communication Server”
