My IC keypad sending two tones instead of one
gazwald
Post by gazwald » 01 Aug 2013 18:04
Hi Folks,
I have an issue where pressing the keys on the MY IC on screen keypad during a call is sending two DTMF tones instead of one. Pressing the numbers on the physical handset works ok and is sending only one tone per key press. Tested and confirmed on 2 different phones and PCs on multiple calls.
Software details are: OmniTouch 8400 ICS version 2.7.200.001 running on 64 bit Windows 7.
This did not happen on the older version of ICS, however we have also upgraded our OXE and I can't be sure when the issue first started, but leaning towards the new ICS client working ok for a while.
Can someone tell me if there is an setting somewhere to tell how many tones to send with each onscreen key press or if this is a known issue? Thanks!
g@z.
Re: My IC keypad sending two tones instead of one
Post by cavagnaro » 01 Aug 2013 19:42
Search the forum. Same question was done a few time ago
Sent from my XPeria Z
gazwald
Post by gazwald » 02 Aug 2013 00:31
Thanks mate,
I did try searching but it's guessing the wording that other people use to describe the same issue that's difficult :)
g@z.
gazwald
Post by gazwald » 02 Aug 2013 01:25
Ok I used some other terms and found the thread I think you were talking about: viewtopic.php?f=285&t=22061&p=78436&hil ... nes#p78436
Seems to have occurred after an upgrade from 9 to 10 just like we have done. No solution offered as yet however. Thanks.
g@z.
