Couldn't configure voicemails on 8440
bibou
Post by bibou » 03 Mar 2011 10:37
Hi all,
I've configure this week a voicemail 8440 with a Red Hat 5 Update 4 64 bits.
I've installed the last version 6.1.000.103c and I used the Boot CD for OS 64bits.
All the configuration steps went fine : I used the deployment file sent with the Actis, replaced the alcotuc.lic file (the MAC address specified is the good one).
Then I installed the TTS motor and desired languages, configured the Call Server via the web interface, the media server etc......
The SIP registration on the Call Server is done, and I call the voicemail, and begin the configuration for my voicemail.... I register my name, define a new password but at the end of the configuration, I've got the following message :
"You haven't granted access to this application. Please contact your administrator".
After some research, I found that the directory /var/vms/ngvm2 which stores all the voicemails, is not created on my 8440 server.
I think that this is a root cause of the problem that I explained below.
Does someone already get this kind of problem, or has any clue to fix it ?
For information, I've already installed 2 others 8440 voicemail on my network (but working under a Red Hat 32 bits system), and I've never get this kind of message.
I'll be greatful for your help.
Thanks.
ACSE OXE R9/R10 certified
Arkoon firewall ACSA certified
Omniswitch R6 for IP Telephony certified
bibou
Re: Couldn't configure voicemails on 8440
Post by bibou » 15 Mar 2011 06:44
I've solved the problem:
I had to put access right "chmod vmuser:vmgroup" to directories /var/vms and to directory /var/vms/ngvm2.
skipper-com
Post by skipper-com » 22 Mar 2011 06:58
Bibou, thank you very much for so great research! I've change the rights and voice mail works now.
nadeeem
Post by nadeeem » 28 Feb 2012 04:51
Can you please tell in detail the procedure to grant access?
nadeeem
Post by nadeeem » 01 Mar 2012 07:29
ok i manged to configure it and now its working fine. thanks
komar_666
Post by komar_666 » 12 Jun 2015 07:19
the good command to affect right is:
chown vmuser:vmgroup "to directories /var/vms and to directory /var/vms/ngvm2"
gogo22
Post by gogo22 » 18 Jan 2016 06:32
while configuring the call server , and when trying to add network identifier , i got Error message "this node identifier is not unique"
attached: snapshot from the error message.
how can i overcome this issue ?
note: i tried to set more than one value (0,1,2,..........) But got same message.
waiting your appreciate response.
Post by cavagnaro » 18 Jan 2016 19:46
Change the node ID on pbx
Return to “OmniTouch 8440 Messaging Software”
