Questions about Local Storage
jasb
Post by jasb »
Hi guys,
In my 8440 I use Local storage, all statistics and messages are stored in /var/data/ics-group/ngvm3
Inside I have:
- Folder statistics (Xml, Html and Csv)
- Folder Source with messages
- And many folders with an ID in this folders I have files named for example "20;00XXXXXXXXX;1449134656637;n;;8c7a877a-ab89-499b-91b5-6d6204786976
I don't know how it works but 20 it's ID from folder in source ? 00XXXXXXXXX it's the caller number but what is 1449134656637 ??
Because I need to found and keep a voicemail from an user. I can do this manually but I want to leave the possibility for users to do themselves can I ?
And last question :) can I backup the content from /var/data/ics-group/ngvm3 with a schedule ??
Thanks.
Split
Re: Questions about Local Storage
Post by Split »
if I remember correctly this could be the name of the saved voicemail message (wav file) that the caller has left ....
ACSE OmniPCX Enterprise Business R9/10/11
ACSE ICS 8400 R6
ACSE OpenTouch R1/R2
Return to “OmniTouch 8440 Messaging Software”
