Failed Emission FAX with error code 500
Abismail
Post by Abismail »
I have a problem when sending FAX, I recive a receipt with error code 500,
Somebody had this problem or a solution ?
thank you in advance.
Re: Failed Emission FAX with error code 500
Yes. I did. And also a solution! :D
Come on..."Hey doc, I feel bad...fix me"
Doc: "Sure take this"
....Doesn't work like that, right?
What are the symptoms? Logs? Where are you calling to...be more useful to help you!
Return to “OmniTouch 8450 Fax Software”
