Problems connecting to OXE
charpdy
Post by charpdy »
What happens in the SIP trace when you look from the teamwork server ?
Monitoring/SIP logs
Have you managed the SIP proxy in Teamwork ?
Can you call the conferencing number from OXE ?
Just my 2€ (ya i know, inflation in EU is crazy)
alex
Post by alex »
RobertBreu wrote: the trace on oxe is empty...nothing!
Looks like a SIP proxy in MTW's configuration is wrong. Where MTW is sending INVITE's when calling OXE's extension?
You can check MTW's SIP call traces in Admin menu "Monitoring/SIP logs".
When the configuration is OK there must be a string like that
INVITE sip:<OXE_extension>@<OXE_address> SIP/2.0
RobertBreu
Post by RobertBreu »
i have just checked the sip-logs...for me it looks like that the invite message from the teamworker-server is wrong, her an example:
192.168.92.204 = OXE
192.168.92.208 = MTW
2010-05-11 20:21:44.765951
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.92.208:5060;branch=z9hG4bK132233142;received=192.168.92.204:5060
Call-ID: 963602151@192.168.92.208
CSeq: 1 INVITE
From: "robert.breu" <sip:robert.breu@call-data.de>;tag=3495733440132233140
To: sip:+@192.168.92.204
Content-Length: 0
2010-05-11 20:21:44.817164
SIP/2.0 404 Not Found
CSeq: 1 INVITE
To: <sip:+@192.168.92.204>;tag=8e64ccbe5644ece51ee248d2cb00b6af
User-Agent: OmniPCX Enterprise R9.1 i1.605.14
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Content-Length: 0
2010-05-11 20:21:44.817608
ACK sip:+@192.168.92.204 SIP/2.0
CSeq: 1 ACK
User-Agent: Alcatel-Lucent 8460 ACS 8.1.0b5031
Max-Forwards: 70
Content-Length: 0
I want to dial extension 22 but i think the teamworkserver just dials + ?? (I have marked the parts that maybe wrong)
Is this an issue with these DAS Rules??
The trace on the oxe shows the same!
From the oxe i can't dial to the teamworkserver. When i dial the number of the external voice mail to reach the MTW-Server i get a busy-tone (in my example i dial the extension 548). Do i have to set the extension (548) somewhere in the teamwork-server to reach it?
Thanks a lot for your help
alex
Post by alex »
RobertBreu wrote:Is this an issue with these DAS Rules??
Sure. Do you have a DAS rule for extension calling?
Check this post on old forum basic DAS rules thanks to cavagnaro.
RobertBreu
ok i have tried some DAS-Rules and now i can dial to extensions on the oxe. But what do i have to configure when i want to dial from oxe to mtw? I have tried to create an external voicemail system but this doesn't work? What do i have to configure on the MTW?
Please follow the installation guide, it is explained all in there..
alex
Post by alex »
Actually, cav is right. If you open "My Teamwork Site preparation guide", chapter 9, you have all the instructions how to connect MTW and OXE. I see no sense in retyping it here.
chris2109
Post by chris2109 »
yep...it seems that you´ve not setup the registration in the teamwork platform under configuration / SIP proxies...here you must declare the SIP User Name...also it is necessary to configure the External Voice Mail in the OXE...
banfield
Post by banfield »
RobertBreu please add me on msn messenger daniel_banfield@hotmail.com i show you have to do the configuraton in OXE and TWK. BR Daniel
Return to “OmniTouch 8460 Advanced Communication Server”
