Teamwork 9.1.0b6251 log files
au190
Post by au190 » 03 May 2013 03:27
Hi I woud like to see the sip Log but I can not find it.
In former version 8.5 the sip logs was under MONITORING -> Sip Logs. Here you saw all of the sip trace logs of the calls.
In this version I can see only
/var/log/tnslog/tp240dvr.log-2013-05-03-02-00
2 files and there is no logs.
Can I set somewhere in the admin to see here the logs ?
If I go to see what is in these log files I can not see the sip trace :(
In the CONFIGURATION ADVANCED SETTINGS SIP LOG LEVEL I set to maximum the log level , but I can not see the sip tracees .
Do you know where can I set the sip traceses and where can I set this ?
BR Robert.
Return to “OmniTouch 8660 My Teamwork Conferencing and Collaboration”
