McAfee says IPView contains a virus
This is an ticket analyzing software for IP Tickets generated by your favorite PBX. If you have any question, feel free to ask Mr_Sven !
mikecel79
Post by mikecel79 »
I went to use IPView this morning and noticed the exe was missing. After downloading it from http://www.ipview-analyzer.de and installing it again McAfee says it contains a virus. It detects it as New Poly Win32 virus. It looks like since the Dec 23rd DAT file it detects it as a virus. Anyone else run into this?
Re: McAfee says IPView contains a virus
Nop, I'm using kaspersky and nothing warned me.
Mr_Sven
Post by Mr_Sven »
I try to contact the McAfee Support
iourid
Post by iourid »
I have the same, so I am using old version - 2.0.0.836.
Great program BTW! Thanks Mr Sven!
Mr_Sven
Post by Mr_Sven »
I got the following answer:
In Mcafee SecurityCenter - > Computer&Files -> Virus-Protect is active-> more , disable "Search for Unknown Viruses"
:? But wouldn't it affect the whole system? Maybe a good option would be to add the EXE itself to some exclusion list...
Mr_Sven
Post by Mr_Sven »
Problem Fixed
Avert™ Sample Analysis
Issue Number:5082009
Virus Research Analyst: Mark Olea
Filename: ipview.exe_
Detected as / in DAT: New Poly Win32 / 5500
Identified: No Virus/Trojan
McAfee Avert™ Labs, Singapore
Thank you for submitting your suspicious file.
Synopsis -
Our Senior Virus Research Engineers have examined the file in question and no virus was found.
Solution -
Attached is an extra.dat with correct detection. This correction will be included in the next DAT update.
EXTRA.DAT
This should be used with any of the McAfee AV Scanners.
The file should be copied into the directory where the other DAT files reside.
Using the find/search utility on your computer search for the following file:
SCAN.DAT
Then copy the Extra.dat we have sent you to the same folder where one of the above is located.
Once you have copied the file, reboot the system for the driver to be loaded.
Return to “ipview analyzer”
