INTIP3 CS Role Address IP trouble
kjetil123
Post by kjetil123 »
When I change my network information from netadmin, and change the INTIP3 IP address under ethernet parameters, the INTIP3 board remembers the old CS role address as seen under mgconfig on the INTIP board, instead of pointing towards the new address. This causes the board to stay in INIT 1 RUN, and trying to download binaries from the OLD address, and subsequently failing.
I have changed the IP addresses under lanpbxbuild to point towards the new addresses I put on the CPUs.
Since the IP options under mgconfig are greyed out, I can't manually set it there.
Any way I can force the INTIP3 board towards a certain address?
Thanks,
oldboy
Re: INTIP3 CS Role Address IP trouble
Post by oldboy »
do a ippstat option 1, is the address still the old one (which i believe it will be), reboot the system and see how it goes!
murraya
Post by murraya »
lanpbxbuild? must be intipB card. if you have dual cpu you could try double bascul.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Boards”
