HTTPS [login4] - soap login error
smith_user
Post by smith_user » 19 Aug 2015 22:10
So a few weeks back we upgraded the software on the oxo to ALZAU920/061.001 which solved a number of problems that we were having. We also updated the Omni PCX software to 10.0.13.1a. Everything was working fine a few weeks back, however now when i go back to login to the PBX i get the error in the picture below
Now i have disabled all firewalls and i can login using the exact same username and password for the web services. I dont understand why i cant login? can anyone point me in the right direction?
fe80
Re: HTTPS [login4] - soap login error
Post by fe80 » 15 Sep 2015 11:35
have seen the same behavior on one R8 and two of my R10.x OXOs. Someone may open an eSR ;-)
fe80
Post by fe80 » 25 Sep 2015 05:04
Hi smith_user,
It seems to help to do an OMC dial in with modem or ISDN to the affected OXO. Can you confirm this?
Saydo0o
Post by Saydo0o » 26 Sep 2016 01:45
I solved it as follow:
Go to Internet Options >> Content Tab
Then Clear SSL State
Saydo0o
8crespo8
Post by 8crespo8 » 22 Aug 2017 16:32
Hello everyone, can someone help me with the following problem, I have an OXO Connect R2.1 I have problems when entering by OMC I get the error of:
HTTPS [login 4] - Soap login error - Error Code [29]
Beforehand thank you very much
Return to “Configuration”
