Hello guys:
I need to know how to do the following:
The operator want to call an external number, and then, without expecting to attend, transfers the call to a internal number (her boss); the operator hungs of; and the boss is waiting for the external hung up.
Thanks!!
External blind transfer
Re: External blind transfer
Hi fernan05
You need to configure simulate off hook time. Which kind of trunk do you have?
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
I have PCM-R2 and analog trunk.
Where to configure simulate off hook time?
Thanks!!!
Thanks!!!
Go to external lines --> protocols --> analog trunks 1 NDDI and press modify:
Modify all Off-Hook simul timers to the time you want. In analog time I use 3000 ms.
Go to external lines --> protocols --> analog trunks 2 PCM and press modify:
Modify all Off-Hook simul timers to the time you want. In analog time I use 3000 ms when I don't have metering. When I have metering I use 90000 ms. Why this? Because in PCM trunks you have Off-Hook signaling. You put these times as 3000 ms, if B side answers after this 3000 ms all tickets are printed with call duration time as 00:00 . You put these times as 90000 ms, when B side answers the tickets are printed with call duration time due to Off-Hook signaling from E1 PCM R2.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
I know it is not the section, but is a similar way to do this in OXE?
