Two phone devices in one line
georbe
Post by georbe » 27 Mar 2014 10:32
I have an Alcatel 4200E PBX system. On this PBX system I have installed several DLC8 (digital) and SLC8 (analog) boards.
Whenever I plug two phone devices in one analog line (using a splitter) everything works as expected. The users can call from and answer from any device connected on this line.
My problem is that I want to connect one digital phone in a DLC8 board, and one analog phone in a SLC8 board, using the same extension number.
And whenever someone calls this extension number, I want both the devices to ring.
How can I do this?
Thanks.
enio.eltz
Post by enio.eltz » 27 Mar 2014 15:55
Hi georbe
This is not possible with 4200. You must have two numbers, one for each extension.
Then, you may use dynamic routing to call both extensions with the UA set number.
Best regards.
Enio Eltz Filho
ACFE OXE R12/R11/R10
ACFE OXO CONNECT R2
ACFE OXO R10/R9
Friday
Re: Two phone devices in one line
Post by Friday » 27 Mar 2014 17:07
Another soultion:
Create a hunt group (parallel) and make the two phone members of this group.
The number for the hunt group will be common number for the sets. Both sets will ring at the same time.
Then, to make it perfect, go to each subscriber, click the "Misc." button and fill in the number for the hunt group in the field "Alternative CLIP/COLP number" at the bottom.
Now the sets will show the hunt groups number at outgoing calls.
Fridays are the best.......
georbe
Post by georbe » 08 Apr 2014 08:32
Thanks.
I will try this first thing tomorrow morning and I will post the results here.
Return to “42xx Systems”
