802.1x TLS 1.2 via console
ste
Post by ste »
i have a Problem to change the TLS Type from 1.0 to 1.2 via telnet.
The activation with "dot1x tls on" activate the 802.1x authentication with TLS 1.0.
But how can i change the Type of TLS 1.0 to 1.2 via console?
Thanks in advance!
Re: 802.1x TLS 1.2 via console
By default both 1.0 and 1.2 are activated on the phone.
ste
Post by ste »
thanks for the answer.I have a brand new Phone "8028 Premium DeskPhone" with sealed "original packing" and by default there is also "TLS on" and "USE TLS 1.0" enabled, but "USE TLS 1.2" is disabled.
Is there a way to change the Type to "USE TLS 1.2" via command line or can this only be done direct on the phone?
Thanks in advance!
In TG 0028 you can find the use of dot1x command on the phone, however the last version of the document is written I think before the implementation of TLS version options. So there is no reference for a command for TLS version change from command line....
I think you should raise an eSR for this.
Return to “Networking”
