Outbound SIP-trunks problems
cmksgmbh
Post by cmksgmbh »
Dear,
we are running a OXO R10.3 in a mixed enviroment (T0, UA, SIP-Trunks).
As SIP-trunks we are using Geils (nyagw.voipbackbone.net) and easybell (sip.easybell.de).
When a SIP-client initiates a outbound call with authentication the way is always the same:
client -> host: INVITE number
host -> client: 100 trying
host -> client: 401 unauthorized + login token
client -> host: ACK
client -> host: INVITE number + token + logindata
host -> client: 100 ringing
If there is a SIP-proxy involved it is nearly the same:
host -> client: 407 Proxy Authentication Required + login token
client -> host: ACK
The second example works well on the OXO - it is i.e. the easybell way. The first example works not on the OXO. The OXO will not do the second INVITE with the credentials.
Do have anybody experience with such strange behavior?
I am appreciative for and hint / idea.
Re: Outbound SIP-trunks problems
Because the SIP host should ask that credentials are needed and then OXO sends them. As them so do that.
cmksgmbh
Post by cmksgmbh »
Yes, I know that. But the OXO dont send them in the first case.
http://www.voip-info.org/wiki/view/SIP+Authentication
Read more about SIP Authentication.
Return to “H323 / IP / Pimphony”
