External Call forwarding problem
jp choudhary
Post by jp choudhary » 22 Aug 2015 07:51
I have a OXO R10.1 that has external call forwarding issue (internal call forwarding is working fine ) i enabled Transfer Ext/Ext,,,Transfer Ext/Ext by on hook,, Transfer by on hook, in System Miscellaneous >>>> Feature Design >> Part 2 >> and In Part 3 External Diversion Mode >>Jonning
and i have enabled External Diversion in Subscriber >>Ext.>>Feature Rights >>Part 1.
Plz somebody help me
enio.eltz
Re: External Call forwarding problem
Post by enio.eltz » 24 Aug 2015 10:21
What kind of trunks?
Did you enabled check-boxes in traffic sharing --> joining?
Enio Eltz Filho
ACFE OXE R12/R11/R10
ACFE OXO CONNECT R2
ACFE OXO R10/R9
jp choudhary
Post by jp choudhary » 25 Aug 2015 07:44
we are using ISDN (PRI) Trunk and i enabled joining aslo (ISDN to Analog and ISDN Analog to Analog and ISDN
enio.eltz
Post by enio.eltz » 25 Aug 2015 07:51
Antoher thing, did you configure link category of ISDN trunk? It must be allowed to make external calls.
Regars.
Enio Eltz Filho
ACFE OXO CONNECT R2
ACFE OXO R10/R9
jp choudhary
Post by jp choudhary » 27 Aug 2015 04:11
ISDN category is on default state and there is no External call problem meaning subscribers are calling outside.
enio.eltz
Post by enio.eltz » 27 Aug 2015 06:53
This may be your problem, ISDN access must be allowed to make extenal calls. If it is in default state 16/16/1/1/1/1, I would program as 8/8/7/7/7/7 (as I do here), giving the ISDN access to external lines. ISDN access needs to have the same link category of a no barring set.
Regards.
Enio Eltz Filho
ACFE OXO CONNECT R2
ACFE OXO R10/R9
Return to “Applications”
