Hello all,
I am about to do some changes in an OXE digital trunks E1's, but after doing some checks I have found kind of strange configuration in direct speed dial.
[ 737 ] Instances: Direct SpdDl No. Pref.-------------------------------------------------------------------------------------------------------+
| -> DDD7923 DDD7584 DDD7623 DDD7662 DDD7701 DDD7740 DDD7779 DDD7819 DDD7858 DDD7897 DAD7574 DAD7733 DAD7802 |
| DDD7922 DDD7585 DDD7624 DDD7663 DDD7702 DDD7741 DDD7780 DDD7820 DDD7859 DDD7898 DAD7575 DAD7734 DAD7803 |
| DDD7924 DDD7586 DDD7625 DDD7664 DDD7703 DDD7742 DDD7781 DDD7821 DDD7860 DDD7899 DAD7576 DAD7735 DAD7804 |
| DDD7920 DDD7587 DDD7626 DDD7665 DDD7704 DDD7743 DDD7783 DDD7822 DDD7861 DDD7900 DAD7577 DAD7736 DAD7805 |
| DDD7925 DDD7588 DDD7627 DDD7666 DDD7705 DDD7744 DDD7784 DDD7823 DDD7862 DDD7901 DAD7578 DAD7737 DAD7806 |
| DDD7926 DDD7589 DDD7628 DDD7667 DDD7706 DDD7745 DDD7785 DDD7824 DDD7863 DDD7902 DAD7579 DAD7738 DAD7807 |
| DDD7935 DDD7590 DDD7629 DDD7668 DDD7707 DDD7746 DDD7786 DDD7825 DDD7864 DDD7903 DAD7580 DAD7739 DAD7808 |
| CC10 DDD7591 DDD7630 DDD7669 DDD7708 DDD7747 DDD7787 DDD7826 DDD7865 DDD7904 DAD7581 DAD7740 DAD7809 |
| DDD7936 DDD7592 DDD7631 DDD7670 DDD7709 DDD7748 DDD7788 DDD7827 DDD7866 DDD7905 DAD7582 DAD7741 DAD7810 |
| DDD7931 DDD7593 DDD7632
Node Number (reserved) : 101 |
| Instance (reserved) : 1 |
| Direct Speed Dial No. Prefix : DDD7923 |
| Call Number : B10020 |
| Directory name : -------------------- |
| Directory First Name : -------------------- |
| UTF-8 Directory Name : ------------------------------------------- |
| UTF-8 Directory First Name : ------------------------------------------- |
| Call Restrictions - Barring + False |
| Overfl.Dir.Spd Dl.No. Pref. : -------- |
| Auto.Attendant Calling Right : 0 |
| Call Type + Normal |
| Timed Forward.Dir.Spd.Dl.No. : -------- |
| Range Number : 255 |
| Can be Called/Dialed By Name + NO |
| Displayed Name : B10020 |
| External DISA Dir.No. : --------
and for some reason these numbers match with the DID's configuracion.
-Review/Modify: DID number translator rules---------------------------+
| DID num. transl. identifier : 1 |
| First External Number : 6850 |
| First Internal Number : DDD6850 |
| Range Size : 90 |
| Unique Internal Number + NO |
Any help to know how this works.
Thank you in advance.
Speed dial Number starts with DDD
- cavagnaro
Re: Speed dial Number starts with DDD
PSTN sends header and sufix number
OXE parts it and works with suffix only (you configure this)
As there the DID translator table will use common numberin plan
This scenario as abbreviated, but could be extensions directly
Benefit of this scenario is that abbreviated don't use standard numbering plan and saves it for other uses. I still would prefer to work with DID tables.
Hi, I use to do this (and others did as well) when you needed to split DDI blocks to non consecutive numbers. it was needed as there was a small number of ranges per DDI translator (32 I think).
So you may be seeing the old required config and you can move the translations back to the DDI translator if you now have later version OXE.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
thanks guys,
I think both answers match, so I will do what you recommend.
I appreciate your help.
