How to configure fax and what license need
snowblack93
Post by snowblack93 »
Dear all,
I am newbie of OXE.
Please help me, how to configure OXE to connect fax machine.
And what is license needed for FAX.
Thank u so much.
Re: How to configure fax and what license need
Fax is an analog set. That is it.
snowblack93
cavagnaro wrote:Fax is an analog set. That is it.
This so easy. Thank you so much ^^
lol yes it's so easy analog line ? YOU CAN ALSO add analog type =fax (you can found it at the end) , but if you have some E1 LINES witch ²desserve this fax machine try to mnage the isdn teleservice to fax group3 and see what happens lol? i was stucked when i discovered it
Redafakher
Post by Redafakher »
Hi For All
iam Stuck now in that case but i have an issue
i have pri And a FAX connected to my Sli board and the fax received a Voicecall through the PRI But didn't receive any fax .
i hope some one know what is the problem
thanks a lot dears
try to configure you fax extension as standard set without special services and give it a try
