8088 with Android - HELP PLS :?
GuilhermeArthur
Post by GuilhermeArthur » 22 Feb 2018 09:55
Hello, I did the installation of android on a smart 8088.
but the telephony part is only working, I can not use any applications, in fact the applications do not even appear.
Anyone know how to tell me that 8088 Android has applications to use? should work with video calls ??
Another question, how do I fully remove the Android from the 8088 phone?
thanks.
Re: 8088 with Android - HELP PLS :?
Post by cavagnaro » 27 Feb 2018 12:05
Don't have answers to your question but how did you convert it to Android? Which firmware did you use? Do you have the TC number?
alex
Post by alex » 28 Feb 2018 04:23
TC 2347, ch.6 Switch between Linux (SIP mode) and Android (NOE mode)
Post by cavagnaro » 28 Feb 2018 07:12
Thanks!
swinstu
Post by swinstu » 03 May 2018 09:29
Android is NOE on 8088, Video is currently not supported on NOE so only as SIP device on 8088 phone supports video.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
