OXE-Transit
Marryia
OXE-Transit
Post by Marryia » 08 May 2018 10:11
Hi all,
I have an OXE switch that plays a transit role. it is between a Mitel and an Ericsson switches.there are 2 questions here:
1. I have a trunk between Alcatel and Ericsson that is free but any calls from Alcatel to Ericsson is busy.
I checked any ways with CRC4 and Network Mode. It doesn't work...
2. there is a default DID number in Alcatel to translate 9734052 to 4052 from Mitel to Ericsson but it doesn't work right. in T3 I can't find the Caller number and it doesn't work at all, I think that is for the Alcatel isn't source or destination.
What should I do????
thank you so much for your attention
Re: OXE-Transit
Post by cavagnaro » 08 May 2018 12:33
Start by posting your configurations
Re: OXE-Transit
Post by haroun » 11 May 2018 12:41
config + trcaes please
