Flash Timer OXO panasonic TS500
elias_ruiz_diaz
Post by elias_ruiz_diaz »
Hi!
I wanna use the flash button for transfering calls for panasonic ts500 but it does't work this configuration TimeDurati "00 0C 00 30 00 4B 00 28 00 0C" if it's something wrong please help me, i'm from paraguay, the configuration it isn't by zones? please, if it's something to change, please tell me!
thanks!
Re: Flash Timer OXO panasonic TS500
You need to know the flash timer parameters from Panasonic and you need to configure them in Alcatel.
javismexican
Post by javismexican »
Hola si es un TS500 nuevo estos ya son a 100msg, si son anteriores son a 600msg debes ponerlo: 00 OC 00 60 00 4B 00 28 TE FUNCIONARA
8crespo8
Post by 8crespo8 »
Hello everyone, please someone can help me to have the correct parameters in the flash timer variable so that the Panasonic analog terminals can make transfers, the models that are in operation are:
KX-TS550LXB
PNLC1055
KX-TGB110LC
Thanks for the help
