IP + IBS dect on same system
lee1981
Post by lee1981 » 03 Jan 2017 05:02
hiya
just wanting to double check. am I correct in thinking you can mix IBS dect and IP dect on the same oxo. R10.3 firmware.
I got some info from Manuel just wanting clarification.
I am wanting IBS on main site with the OXO and then run IP dect on remote site. I know I will need to give the same handset 2 diff ext numbers so works on both sites.
Return to “DECT”
